So I have this customer that insists the splash shields I show above are missing from this picture of his car (I know those aren't for a 73 Satellite). I'd like to help but I don't recognize this are or the splash shield that would go here.
As far as I know those metal shields are all that go there. They bolt onto either end of the backside of the front valence and to the structure of the fenders. So they are located in the corners where the font valence and fenders meet. There are several seals ... the ones you already mentioned, (the headlight splash shields and the big block passenger inner fender seal)as well as a small squarish seal back on the upper juction of the inner fender/firewall located behind the plastic wheelwell insert and another that lies in the front valence below the radiator that is similar the charger version you sell except it is shorter in length. Attached pic shows the location of the metal panel that your customer sent you.
