Could be front bushing and seal. Could be large pump housing O-ring but Check for too much fluid especially warm.
especially if it does not leak driving and running? does it leak after sitting a while?
Oil pan gasket can cause it to leak down the lower bell housing and drip at front but I'm sure you have checked and know leak is inside bell housing.
