Will the DMI fit with a motor plate? Or just the elephant ears?
Thanks,
Ed
You may need too trim the plate but it will work. It can be set up to also be a crank trigger bracket. They make one for the std size pickuo and also a mini sized pickup. I needed the smaller pickup because my frame rails are narrow and the big pickup was very close to the alternator.
Big pickup.
Small pickup
