Quote: Draw the existing lobe as designed with the designated rocker ratio ie:1.5 ratio,then super impose the same lobe with 1.7 ratio rocker movement and follow the cycle from where the movement starts at the ramp to max lift as well as dwell time.It will travel well outside of the original cam demension.
Taking measurements from the same give point ie: .050 valve lift? Or as soon as indicator starts to move?
