The later 11.75" A/B rotor which fits (from memory) your spindles is a pretty stout piece. Suggest you use that. A good quality replacement rotor (parts store) should be fine. Newer formulation high po brake pads do not "out gas" much once broken in and I don't think slots or holes help much... and holes can start cracks.
