90 weight or 80W90 will work fine for general use. I have always used the parts store LS additive in mine (GM spec?) without issue.
Synthetic can help with temperature extremes: for really cold weather or if running sustained high speed/high temp. An xx/140 dino oil can help somewhat with high temps as well.
