I have always had my Caltracks in the top hole and everybody is telling him to use bottom hole. I upgraded to a 1050 carb and went to the track 1 time so far and I made 4 passes with zero traction. Should I try the bottom hole. Sorry for the hijack, I might make it back to track this weekend.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
