My stock brackets worked on mine, they are suppose to be cast like a cast iorn one so shoud;nt be a problem if you have the right brackets
The intake is a little taller but a stock bracket works, if you need to clearance yours for it to fit that is fine but I don't remember having to do it with my 69 bracket ?
Water water nitrous injection port ???
Don't worry about that hole passage as long as it is not an exh leak.
