Need some help with my new front side markers. Regarding the pig tails : I can't figure out how the bulb socket of the pig tail secures to the bezel. I've searched this site for help, but still can't seem to figure it out from the prior posts/threads. I read where the pig tail's yellow connector gets pushed through the hole via the front of the bezel, but the hole is smaller than the width of the connector, and if this method were correct, I cannot see how the bulb socket would be tightly secured to the bezel. Consequently, the bezel hole for the bulb socket is too large for the socket to be attached from the rear. Also, there is a rubber washer that came with the new side markers. I don't know where on the pig tail this would go. Any help would be appreciated. BTW - I tried to fit the new pig tails into my original bezels, and it's the same situation. I'm not re-chroming my originals because they're just too badly pitted. Thank in advice for the help.
I spy PG Classic parts? Send them to me Joe, I'll press them for you no charge. I made a special die I use to press all our pigtails "before" they're shipped.
You'll like to never get them in without the proper tools.
http://www.beaparts.com/item_detail.aspx?id=579
