Do not use the edelbrocks unless you are working on late 73 & up B body fronts.
what eddelbrocks are you talking about ? IAS eddys doesn't fit in front. they are longer to get the inner fender location, what in 73 and later is a lower location.
KYB's used to be good. Still they "porpoise" when they get hot. OK for a driver.
Mopar HD or the HD monroe's actually work very well.
what would it be your choice between those... I'm trying to go with some to my 74 Charger.
The best shock by far is the adjustabe QA1's and I can't say enough good things about them.
are they available to 73 and laters B bodies and what's the price ?
![](/ubbthreads/images/graemlins/grin.gif)
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
