I'm sorry but I'm going to have call bs on this too.
I hypermile the crap out of my '01 360 4x4 1500 w/ 4.10's and the best I can get is 18 at 50 to 55mph. The converter is chopped out, it has a Flowmaster 40 and an electric fan.
Also I would have to see this 3/4 ton "spin the tires" (on dry pavement, I'm assuming) to believe it.
4.10s are killing you, running around with no load is making the engine fight vacuum to pull the piston down and friction is a lot higher. It is pretty funny to hear some put hyper-miling and 4.10 gears in the same sentence
