Thanks for the replies. It is a 1974 trans case, and does not have a load control servo. I disassembled another trans with the same type servo and removed the larger diameter spring and installed it in the 1974 case. I guess I will find out how it works. My thought is that the band will release quicker with the added spring tension.
