The bars are rarely the same size. Proper sizing depends on the spring weights, weight of the car, balance of the car, and a few other things.
In general, the rear bar will be significantly smaller than the front to promote a more controllable understeer at the limit.
I used a factory 7/8" bar on the front of the hot rod and a 3/4" bar on the rear. It handled fairly well.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
