Very simple....
42RLE is Gas engine
45RFE is Diesel engine
There are 2 variants of the 42RLE in `06 depending on which way it was ordered...One with Variable line pressure and one without
Talked to Scott
He said that tranny has 3 speed sensors
Find someone else to talk to...BOTH the RFE and RLE have only TWO (input and output) speed sensors.
Raff...to answer a couple of your questions...NO you can`t change the line pressure, NO you can`t change the idle speed
Has this had the fluid changed lately ?
Rick
I dont think so.... I bought this 06 used a couple
of months ago but havent driven it much(I was out
west with my other ride,wife's truck)I did see that
you should use 1 type of fluid only otherwise it
could/can have issues. Since you say the idle and
trans are a fixed condition(cant be changed) how
do I get the idle up a couple hundred revs.. is this
all in the computer, if so, do I get it re-flashed
and the same with the trans. This is under warrenty
but I would prefer to correct it before it really
be comes a major problem
thanks
