Nice! What is the engine specs?
Started with raw KB block now it's a 4.5x4.5 572 , heads are based from a -13 but 100% done by Goodwin. Valve train designed and built by Todd, sheet metal manifold (again Goodwins design), and (2) 1050 HP carbs.
I run a 727 and footbrake, launch at 3000 and shift at 8000/8300
Wow, you shift that high. What' the cam spec??.
This might be my favorite car on this forum. Sweet. What's the cam spec
Thank you very much! I greatly appreciate it. It's taken us 7 years to get to this point.
Wish I could tell you the specs, Goodwin doesn't give out much info. I can tell you it's 50mm plus diameter with roller bearings. I asked the question when I was watching them assemble it and his reply was "it's not much". I got similar responses when I inquired about compression, valve size, head flow, etc.
I can tell you Todd's service and support is nothing like I ever experienced. He makes himself available 24/7. So I guess with that support I never minded what makes it tick.
