I just got my Dana together, and everything went well. Thanks to Dr. Diff on how to setup the clutch pack and general knowledge. Also thanks to Bob George.
Anyways, so Dad and I set it up and everything went good. Other than a leaky new cover, the clutch pack seems way too tight.
I coated the new clutches liberally with straight friction modifier. This was about an 8oz bottle than came in the Yukon rebuild kit.
Well, this thing is like a spool. I didnt' get to do more than just break the gears in (about 15min drive). THe parking lots were still wet and salty, so I couldn't do the figure 8's to work the clutches, as the tires would slip first.
So in the mean time, should I add more friction modifer or will time and bends loosen up those clutches?
