71 Scamp 318
Just bought this car. There is no passing gear or downshift with heavy acceleration. The kick down linkage was hooked up to pull the lever on the side of the trans to be pulled forward under acceleration. isn't that backwards? I used a tie-strap and held the lever at trans to the rear and still will not kick down under heavy acceleration.
All MOPARS & nothig else.
