From Hebron go north to mass pike west to exit b3 I think, first exit after toll booth, when you get to track pass the main gate on right and go in racer entry just pass the go kart track, you should be ok with tech, just make sure helmet has proper snell rating..
Helmet is all set Snell 2010
I think I will remember as soon as I get there, I just remember passing a lot of wooded roads and a few trash container manufacture companies on my way in. Pretty easy ride if I remember correctly.
Thanks for the advice.
