Again, my car fell on it`s face past the 1/8th w/a black Holley and the Aeromotive.............installed the 300 Magnafuel and had to re-tune the carb and went solid 9`s. And my car`s not that bad azz............
Ummmm, if you "had to retune the carb", how do you KNOW the pump/reg was causing your problems?
I once tried a billet cement mixer pump and high $$ reg on a low 10 second combo, replacing JUST the 10 year old Blue pump and reg. Adjusted the PSI to be the same, and ran it. Weather station was identical to the weekend before and said I should go 10.30's based on my data. (With the old Holley stuff).
Guess what??? 10.30's at the same speed with the new (thankfully borrowed) high $$ "junk".
It LOOKED trick though...
Gotta agree with ya. My old 9.80's car( 3350 weight) ran a Holley black and Holley large port regulator for years. Ultra consistent car, saw about 7500 at the stripe every pass. I caved in to peer pressure and went hog wild witha return style way bigger pump/ lines,etc, etc..... And saw zero difference after throwing a grand at a nonexistent problem. My new car is much slower, but I run a pump similar to a black on it through the stock tank sock, 5/16 line and small Holley regulator. It pulls hard on the back half of the track for what it is, zero nosing over. I have no concerns it's leaning out. Just my
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
