I know someone recommended the radium(sp) ones.
are there any others?
I don't want to cut up my tank, as I coated it before I installed it.
I have seen the diy one using the remote filter kit, but kind of wanted one to hold the pump too for a cleaner install.
also is there a small intank pump that fits in the existing hole? maybe do a compression fitting to the existing sending unit tube inside the tank?
65 coronet.
