I was going into rd 4 at the track last night and the starting line crew had me shut the car down due to a leak (thank goodness they were on the ball).
Just like the title said, is there an easy way to fix a crack on an oil pan ( on a weld). It is a Milodon 7 quart low profile pan. I realize that I will more than likely have to pull the motor and replace the pan....but I thought I would ask.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
