Re: R&D For Both Big/Small block
[Re: 74yellowduster]
#1664656
08/28/14 09:04 PM
08/28/14 09:04 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
http://thitek.net/news/jesses-200mph-challenger-hot-rod-magazine/
Built by Spankin Time Performance in San Bernardino, California, Jesse Iwuji’s Challenger uses a Darton-sleeved, 408ci Hemi stroker crank from Scat spinning a set of Carillo rods and CP pistons. The engine also has ThiTek heads and a 4.2L Kenne Bell supercharger that runs as much as 22 psi of boost on E85. The exhaust uses OVX long tube headers, Bassani mid-pipes, and Flowmaster Super 40–Series mufflers.
The 912 rwhp gets to the ground by way of an SHR transmission, a DSS driveshaft, and the stock differential and axles with 3.06 gears. With that combo, Jesse became the fifth modern Mopar to break the 200-mph barrier in the standing mile, running 200.9 mph. He’s also run 174 mph in the half-mile, which is the same speed our showroom-stock ’13 Dodge Challenger SRT ran in a mile and a half.
http://www.nmcadigital.com/2013/09/19/br...r-for-rob-goss/
i guess some R&D must be goin on
The be blunt........so what...........ain't nothing about that really impressive. A new HEMI with a blower that makes a little north of 1100hp.......Trust me, that is NOT tough to do with any decent smallblock of ANY make.
And where is the R&D part of it. You take a decent shortblock, put some good heads on it........add boost. Easy power, been done for years. Because its a Mopar, we think it is something spectacular, when really it is run of the mill........and THAT is the reason the Mopar aftermarket is not supportive. Not enough people out there doing it
Monte
