Bill, Do you add bronze throttle shaft bushings on your carbs? Mine are loose and I'd like to buy a kit with the bushings and reamer if you have a source. Also need to buy screws for the throttle blades as I know that these will break off.
Thanks,
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
