My truck is an 84. I have the 91-96 drop spindles. I know that I have to shave down the caliper bracket to get it to mount on dakota spindle. My problem is that the rotor touches where the tierod mounts.
I haven't read anywhere that the tierod mount needs to be shaved down so to not rub the rotor. So what I want to know is if I use a 85and up rotor will I have the same issue? bolt pattern change would be in my favor so that's not an issue.
This is why I was asking for people who have actually done this with the real experience. If you haven't done it, you won't know 100%
