Quote: Stock header bolt location yes...But far from a stock exhaust port. J,X or eddie, and pro comp is a stock exhaust port.I wish i could post pictures.
I'm agreeing with you. If he has to retain stock exh. Flange I would not use the Indy heads I don't know which would be best. I've seen several cars run great with the eddies
