Anyone got a pic of what the top of the intake manifold bolts should look like? Are they different since they are mounting to aluminum not cast iron? Thanks
Intake bolt - 3/8-16 x 1 1/2", 9/16" Hex,
"TR" head marking , Black Phos
And, when used on the Edelbrock aluminum manifold, they used washers under the head.
And they weren't lock washers !
washers are a 3/4" outer diameter flat washer and I think are aluminum sixpack manifold only???
