Re: Switch from 10-30 to 20-50 pressure change?
[Re: Hemi ragtop]
#1659179
09/01/14 11:58 PM
09/01/14 11:58 PM
I just don't buy this "it is a HEMI so it is going to use oil, put up with it". I built 12 big block Chevy's, all the way to an all aluminum ZL-1 before most of the world knew there was one, NONE of them used oil. My last one was 11.6 to 1 steel head in a full size 70 Chevelle with air, 3:31 gear, turbo 400 and after 500 miles, it got 30 weight Mobile 1. Never leaked or used oil. That was in 95'. Same engine still in car, sold it to a buddy and it still doesn't use oil. Hell, I used to drive it on weekend trips, several hundred miles on 93 no lead, remember 11.6 to 1., iron heads, 4,000lb. Careful hand blending piston dome, Zero deck height, combustion chamber work and distributor curve WITH vacume advance! Don't tell me that I can't build a HEMI that doesn't use oil!
Why all the Drama over an Intake Gasket Leak ???!!
