I removed my foam years ago because of the alcohol in pump gas with zero issues. These are the instruction that came with my BG400 pump.
Bypass
The return line should be fed with a single #8 or
1/2" line. Plumbing kit number 150187 is avail-
able for this application. The return should expel
the bypassed fuel into the liquid rather than into
the air space of the fuel cell. This will prevent
aeration of the fuel. All fuel tanks and cells
should have fuel cell foam installed to prevent
fuel slosh.
WARNING: DO NOT BLOCK THE RE-
TURN, VENT, OR PUMP FEED. MAKE
SURE THAT THE SYSTEM IS LEAK FREE
AT ALL CONNECTIONS...YOUR SAFETY
DEPENDS ON IT!
Wiring
BEFORE MAKING ELECTRICAL CON-
NECTIONS, DISCONNECT THE POSITIVE
TERMINAL FROM THE BATTERY.
Your BG400 Fuel system should be connected to
a fully charged 12 or 16 volt battery. A fuel
pump, like any other electrical accessory, will
only perform at its best when given adequate
voltage. The black wire is a ground (-) and the
remaining wire is a switched hot lead from a 12 or
16 volt source. If wired incorrectly, the pump wi
I know sometimes I'm a bit out in left field, but I have thought about this before. like in a fish tank where water flows out of the filter and dumps into the water, its adding oxygen to the water, is it possible that when fuel is dumping into a fuel cell, is it adding oxygen to the fuel similar to some race fuels that are oxygenated
Whatcha smokin there 6.................. But it actually makes sense for some crazy reason.
Except for the fact that the pump doesn`t wanna suck bubbles but solid fuel.............
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
