On the cheap this is what I'm doing:
Found a 3/4 ton 2wd for a donor, get the brakes (bigger), front sway bar (bigger), front coils (stiffer), lower control arms (for lowering, search the truck section on how to do this).
Keep my 1/2 ton rear leafs, subtract a leaf to lower it (and soften the rear).
Get a rear sway bar from a 2Gen 3/4 ton and install.
Enjoy.
In the plan for my old beater, I even located the donor for $50. Just need to get the time to do it.....
Mo' Farts
Moderated by "tbagger".
