3375 w/driver
103.5 mph @ 1/8
8"flash stall @5100
convertor Is what I suspect? still sorting out as
timing change from , jet change, ,shift point resulted same 1/4 only a .005 et difference
mph stays 130.15
weird eh?
Your not doing to bad IMO, maybe just a touch slower then the numbers indicate.
1.38/39 is about 10.20
130.5 MPH is about 10.25
Your picking up 26.5 MPH on the back half, so thats very good IMO. Its not your vert. it seems to be working great. Have you ran at more then just one track?
