I install with the truck on the ground. Tried several different ones. Napa, Oriellys. Even went with higher priced MOOG with greasable joints thinking it would be better but they lasted about a week. As for binding I can't see anything binding. These trucks always feel and look like they are riding over themselves with the tires turned. Also have replaced the sway bar bushings to polyeurathane.
Lasting a week?? That's crazy!!! Something has GOT to be f'd up. I had an '04 and that's one of the few things I DIDN'T have to replace! Is it lifted or wearing extra large tire/wheels? Worse case you could look into an aftermarket bar set-up such as Hellwig.
