I believe its at it peak maybe a little more in it,
I just dynoed my on a chassis dyno so the best I could
figure is it made peak HP at 8000 and I went through
the traps at 8200 but it seemed like it was out of
power before that.. thats why I wanted to try the 4.30s
but if you have a engine dyno sheet that says you make
peak at 7900 or so you should be in the park
