I welded in a four point cage without cutting up the stock interior. My new seats are in, but I haven't put the 3-point belts in yet. They bolt to the rear seat belt bot hole and can be quickly unhooked for rear passengers to use the stock belts.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
