It's going to be hard to run faster then a 6.50 with your combo of parts. The small cubic inches, low stall, and shallow gears are all fighting against a low ET. I'd change the stall 1st. It will prolly be a better ET gain then a cam. If your stuck on a cam change only I don't think there's a lot to be gained and still keep the lift where you want it.
