Short times are good! You need to be looking at why you are losing your good momentum down track. I'm guessing you are running around 101-103. May need to look into fuel jetting to get your top end mixture better, or even converter lock up.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
