I had the PST polys in my 65 B body.Pulled them out and went to Moog problem solvers.It almost got my caster to where it should be.The polys had it at about negative 4 or 5.I did my own alingnments at work so I knew where it was.Most old Mopars dont have enough caster for radial tires.Rocky
what r the problem solvers?
They allow you more offset of the upper control arms during front end alignment to achieve varied specs that "standard" bushings can't achieve
Mike
