Quote: Is an 80-84 front disc brake axle a bolt in for a 72-74 truck? I suppose you may have to swap master cylinders.
As long as gear ratio is the same. They bolt in a little diff but will swap. You can also swap just the knuckles out from any 80-93 and install it on the 72-74 axle
