It appears after some research the the drivers door on my 37 is actually a 36 door (the inner structure is different and my passenger side is the original 37 door. I have found a set for $1100 and that set is actually the opposite of mine. It is a 37 drivers door and a 36 passenger. Do you think if I buy the set and pull the 36 door off my truck and then try to sell the matching 36 pair I can recover my money? All doors are in good shape with very little rust.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
