You killed it!
It sounds like you joined the Rhinodart club.
It's time for a rebuild. Kirk (in the Cowtown club) had a similar thing happen to his truck last fall. I can't recall what the exact failure was but it was something simple that let go. Once it happened the transmission ate itself.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
