I've got a 99 durango 5.2 4WD with 240,000 plus and still going...Was going to trade it in back when it was worth something but now it's around just to see how many miles it will roll up before it's dead...
All the brake and trans lines have been replaced...Some without issue some with an excitement factor on the road...
Had a trans issue under the 32k warranty which didn't come back...
Been through numerous front end wear items...
The wifey learned the hard way about backing down the boatdock too far to unload the speedboat and ended up with a rear replacement..
![](/ubbthreads/images/graemlins/laugh2.gif)
But that was'nt the truck's fault..
Overall a dependable vehicle if you can keep the rustbelt issues at a minimum...
