Brad penn is a no no with e85, look it up. I used joe gibbs, and recently switched to vr1 win no issues. The oil will attract moisture. If you start the car at all, let it warm up. I let mine hit 200f before I put it up to get the moisture out. No vac pump, or evac.
Where did you read that about Brad Penn?????
If the MODS did their job I would not be hitting the notify MOD button. LOL
