Quote: You would need to section the frame to put a shortbox on it. NOT a good idea if you are going to drop a Cummins in it..
A friend of mine sections frames on his Peterbilt twin-turbo Cummins truck-pulling trucks. He even removes some crossmembers to make the frame twist more impressive to the crowd. Hasn't broken one yet....
