Also, a lot of times when installing anything that uses a soft copper or dead soft aluminum washer, I tighten and loosen and tighten and loosen the fitting at least a half dozen times to get them to bed together. I've eliminated a lot of leaking fittings this way.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
