Aye mate. The transverse "z bar" link that bolts to the subframe on the outer end and connects to the side of the trans case on the inner end may be different between the 904 you have now and the 727 that's coming in. www.bigblockdart.com would likely have some good info on this and other issues you will be dealing with.
