Not sure how your is made. My cuda had card board panels that went on afterwards. The Challenger I worked on first did not have those so it was tougher. I stretched it at far as I could and then glued and stuck them in the teeth.
Interesting you mention this... the headliner kit came with covered hard boards. I know for certain that the Dart did not have these when I took the old headliner out. I am pretty sure it was factory original. I'm not sure how or if they would be attached. Would the original sail panel boards be removed (the ones under the headliner) and these used on top in some way?
383, Hemi 4-Speed, AlterKtion, D60
