Those thicker motor mounts probably would help someone with a 67-72 car. This one is a 73 with the spool mounts. Also, I doubt the taller/thicker mounts would help on the RH side. One pipe rests against the oil pan, another against the torsion bar. The thicker mounts would probably lift the engine high enough to allow the idler arm to swing.
