By checking the fuses , what did you do ? did you just check the fuse or did you check and see if there was voltage across each one . I think its a fuseable link somewhere .
I see this all the time! "I checked all the fuses"...meaning someone pulled them out and looked at them.To check fuses properly they need to be in the circuit and powered up...then check for voltage on BOTH sides of the fuse!! A fuse can look good and be open or look good and not have power TO it! Also make sure you check ALL fuses in ALL fuse blocks!
