With all the room inside the engine compartment...the driver side header hit the frame...LOL...
if they would have moved the number one tube 1/2 inch..anyway...
got the header on after flatting the tube a bit..but the engine will not side now on the mount..
so bought a new set of motor mounts.. 3.50 each..lol...hopefully with new mounts and maybe a shim...we will be good to go...
mounted the new voltage regulator..the firewall had the screws already there...got a 12 volt coil coming for the hei distributor...
