comment from the dynamic duo in the booth was that the Mopar Hemi Pro Stocks do better in "bad air conditions".when it counts....the set up,ie jetting, timing,clutch,trans ratios,rear suspension set up, wheelie bar height,getting all of that right for the changing conditions(every round) and having the driver to cut better lights is the key.
