I use 9 NGK in my 11.25 cr, SB that has about 205 cranking psi. I run 93 don't here any knock or pinging I think I'm a little rich at idle with a 4 corner idle carb it's mostly a street car. Plugs look a little dark after 3 or 4k but what the h*ll the pistons are still in it!!
